BFL13's avatar
BFL13
Explorer II
Jun 30, 2013
Inverter Powering Converter No Loop Test UPDATE
Updated here in OP with results of same test using 100amp PowerMax with variable voltage.
Simulated external box with batteries and inverter, RV shore power cord into box's inverter, no batts in the RV, use converter to make the 12v you need
Test in trailer with batt disconnect open, Trimetric to measure amps.
First amps is 7355 converter at 13.8v/ then PM converter at 13.6v.
A. inverter on, no 120v loads, no 12v in rig--0.7a/ 0.6a
B. turn on converter, 12v in rig, fridge on propane-5.2a/6.1a
C. add 120v CFL lamp -6.1a/7.0a
D. add double 12v lamp-9.7a/11.0a
E. add rangehood fan-12.3a/13.6a
F. add turn on tap, water pump on-17.9a/19.8a
I suppose you could use a lower voltage converter than the 13.8v 7355. Rig 12v only needs maybe 11.5v to run things? Of course the amps come from the batts in the external box and that would have solar on it during the day.
I tried the PowerMax for B. above, at three converter voltage levels, setting the pot to get that voltage:
1. 13.6v--6.1a
2. 12.0v--5.7a
3. 14.7v--6.4a
I previously posted the amps test results for when you forget and leave the converter on and there is a loop (don't do that! :) )
I am not proposing doing things that way, but wanted to know how it would work. ( I would likely have a battery in the rig for the 12v stuff, leave the converter off, and just get my 120v from the external box. I would use my 120v CFL lamps instead of 12v for lighting too.)
  • Hi,
    My PD 40 amp draws 2 or 3 watts when there are no loads on it. Next time I have shore power I'll try to send some results to this thread.
  • Yes the converter in this case seems to have a standing draw of about 5 amps which doesn't get any worse when you add loads. The individual loads have the same amps as usual.
    That 5 amps is like leaving a couple of 12v lights on all the time, but would be covered by solar during the day.
    Could be done with another converter type gizmo for fewer amps I suppose.
    I just wanted to test the actual amps using this method after some confusion arose in another thread.
  • Thanks for doing this. One could also use a smaller converter (say 35A) for less amp draw too.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
