MrWizard
May 17, 2015Moderator
TobyRHudson wrote:
Those are good suggestions but, here's my head scratcher. My shore power feeds through the inverter and then is distributed, right? Both shore and the inverter are distributing through the same AC wiring system aren't they? If that's the case, it doesn't seem there could be circuit breakers or wire issues. Either one of those would affect both shore and inverter distribution wouldn't they? I'm new to the RV world. Am I misinterpreting how the system is wired? I am absolutely baffled!
NO.!!!
shore power goes to the transfer switch
from the TS it goes to the breaker panel
then (1) 15 or 20amp circuit breaker feeds your inverter
and only the outlet(s) on that circuit are powered
are you sure everything else has always worked on inverter before
that seems unlikely
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
