MrWizard
May 17, 2015Moderator
TobyRHudson wrote:
MrWizard - Up until very recently, with inverter on while driving down the road, for example, we've had power at the 100V outlets, the TV and the microwave. Now we've got nothing but the TV with the inverter on.
where is the inverter located
how many 120vac cables come out of (connected too) the inverter
only one ? then there is a junction box someplace where the circuit branches
two ? then you need to trace those cables and fine the broken circuit
all the pictures i found show an inverter with ONE duplex GFI outlet on the front, IF that is yours, then you have a loose connection aka broken circuit is a junction box someplace
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
