MrWizard
May 19, 2015Moderator
If as you say... One cable going intos bundle of 120v wiring.. then there is where you have to go check the connections
Goto the hardware store. Buy one of those three light plug in testers to check the outlets
This will tell you if it is open neutral or open hot or no power
. on the bad outlets.. then you know what to look for in the wiring.. Loose white or loose black
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
