Ivylog
Sep 03, 2015Explorer III
I would swap the house over to the good inverter with the refer and run everything on just one. If you boondock often I would replace the bad one with a 500W PSW inverter for just the refer... a 2000W is four times what it needs. This would let you turn off the MS2000 when out of the rig saving some power.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 01, 2026
