noshow905's avatar
noshow905
Inverter problem
I have 2 - 2000W inverters factory installed on my 2011 Fleetwood Providence. Recently I had repairs done to one at the Fleetwood service center in Indiana. Since I arrived here in FL, my electricity usage has gone up dramatically all of a sudden (Doubled), without us using any additional appliances or a/c units. Batteries and inverters appear to be producing properly. Any suggestions?
I did change one of the 6 - 6v batteries recently because of a neg. post problem. The other batteries were new Apr. 1/15. The battery connected to the new one was quite low before I replaced the other. This low battery has charged up somewhat to ~12.5v. The other batteries are all about 13-13.25v, including the new one. The battery was replaced about 10 days ago, should the one which was low be charged up by now?
  • 3_tons's avatar
    3_tons
    Explorer III
    Per the data you've provided, the principle of occums razor would not suggest an inverter problem...
    3 tons
  • You could have another bad battery.
    If you have an energy management center, try shutting down or turning off the inverters one at a time to see which is causing issue.
    Are the inverters the same or is one an inverter/charger?
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
