tealboy's avatar
tealboy
Inverter putting out 98 volts
I'm using a power line cigarette lighter plugin style inverter for inside the cab, running my computer and periodically, for a 32 inch tv for tailgating. I have never checked the voltage until today and was surprised at how low it was.
Is this normal? Is it problematic for my tv, a med size fan or my computer? Worried about damaging the electronics but maybe it is fine. The inverter is a cheap one, maybe $20 or so.
Battery is new reading 12.5 volts and using a basic inexpensive meter to read output.
  • If the tv works all is fine. Just the flat MSW registering low on the pear-to-peak voltmeter.
    Get sine wave or a true RMS meter to read the volts.
  • Considering the cost of a PSW inverter versus a MSW unit. No point is being that cheap in my view.
  • tealboy wrote:
    I added a light load and it went to 110 and up to 118 with a medium load so maybe the no load situation was the problem?
    YES.
    And that also indicates that you do NOT need to throw away your meter. ;)
  • The Modified Sine Wave inverter will not show the proper voltage when using a standard Multi-Meter. I suspect all is well but the meter is wrong.
  • MrWizard wrote:
    Did you read this with devices on, a load
    Or
    Just at the inverter with nothing else connected
    The second method will never give a correct reading
    No load, just connected to the battery. Reading that I need a true rms volt meter instead of my basic one or will never get a good reading
  • Did you read this with devices on, a load
    Or
  • Modified Sine Wave won't necessarily give correct voltage readings.
    How much extra heat are the power bricks producing when using the unit?
