If I want to plug my shore power cable into my inverter I need to switch of the converter correct? Where might I find it in my 2000 Airstream Land Yacht?
Just make sure the receptacles you want to use are not on the same breaker as the converter, which is sometimes the case in RVs. If they are you can change that without too much work.
Using the shore cord to an outside inverter instead of using an extension cord to inside means no mosquitoes getting in the window left open for the extension cord.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
