Oasisbob's avatar
Oasisbob
INVERTER SELECTION HELP?
I bought a Wagan Pure Sine Wave inverter 200 watt continious. It came with a cigarette lighter plug only. It did not have enough power to run my 20 inch box fan except on low. The box fan was rated at 90 watts on high. So I returned the unit after discussing with the Wagan tech folks. So now I am wanting to try again. How big an inverter should I buy? I did try to purchase a cord that would connect directly to my battery and was told they did not make such a plug for that size unit. Guess it was too small though the wattage was nowhere close to 200. I am confused. Any thoughts?
  • The low boltage alarm began sounding. My batteries were fully charged at 12.8. Reading at the wall plug was 12 .4. I found it odd that Wagan did not sell a cord for straight battery connection. I am willing to try it again bue what size inverter is going to work?
  • Are you sure it was the inverter vs the poor battery connection?
    Did it shut down for overload or low voltage?
  • 90w at 120v = 0.8amp
    thats 8 amps at 12v, and does not include conversion loss
    the cig plug did not have enough power capacity ?
    i run a box fan on high plus the PC tv etc using a 300w go power pure sine wave
    600w surge,
    assuming this was in the RV, i really doubt the aux TV 12v outlet which is connected to the wiring for the lights, has enough capacity to fully power an inverter and run your fan ?
    what outlet did you use ? maybe the DASH cig plug would run the inverter and fan
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 31, 2025
