Jhaw's avatar
Jhaw
Inverter help
Hi guys,
I'm wanting to set up an inverter so I can run power off of my battery bank and solar. I had a 2000 / 4000 peak inverter that I had been using, but was tired of not having my outlets working in the trailer, so I tried plugging the shore line, with adapter, into it. It wouldn't power, so I figured it was trying to pull too many amps, and I flipped all my breakers off, and unplugged my converter. And it still didn't work. So I got a 5000 / 10,000 peak inverter, thinking that would help, and it's still having the same issues.
I've read a few posts, and it seems this is a fairly common thing to do, and works for lots of people, so what am I doing wrong? Or if anyone's come across this problem I'd appreciate any help!
If it helps I'm in a 2003 wilderness.
Thanks so much.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
