AnimalHungry
Jul 11, 2017Explorer
Inverter sub-panel - what to do with ground wires
Hi all - I'm new here and have a question about wiring a new sub-panel for my inverter. I have an automatic transfer switch into which I've fed the inverter output and the shore power from the main panel. The output of the transfer switch goes into my new sub-panel (wires on the left-hand side of the panel). I have two breakers which supply the GFI and non-GFI receptacles only - all other devices are still on the main panel.
I've connected the live wire output from the transfer switch to the left-hand live bus, and I've connected the live wires that go to the receptacles to the output of the breakers. All three neutral wires I've connected to the neutral bus at the top, and then I've used a wire but to tie together all three ground wires.
http://imgur.com/a/hfDay
My question is what should I do with the ground wires? The grounds for the receptacles are both connected to the ground bus in the main panel, so I think I don't need to do anything else, but I'm not sure and want to be safe.
Cheers
Simon
Cheers
Simon
