tsweez's avatar
tsweez
Inverter: Where to start? Subpanel or No Subpanel?
Thanks in large part to the community here, this new RV'r just finished his first mod, e.g. creating a new battery location and replacement of the power converter/charger. My next project is installing or at least "preparing" for an inverter installation. I'd like to do as much of this as possible as to control cost, but under no circumstances do I want to sacrifice safety. If I can get this most of the way complete, I'd be a happy guy.
Here's the scoop...
The scope is to install,(as much as is safe) a 12v Cotek 1500 PSW inverter. This inverter has an internal transfer switch and AC breaker. I want the inverter to power all my coach outlets except for A/C and the Microwave. I don't want any manual switching here at all, rather, have inverter setup so it acts much like a UPS in the absence of shore or generator power. Likewise, I want the inverter to bypass should shore or gen power be available.
For reference, my AC panel already has the Microwave and Air Conditioning on their own breakers. The remaining coach outlets (the ones I want on the inverter) are all on the same breaker including the GFCI outlet in the bath. This breaker is also wired to my converter/controller with what appears to be a pigtail of sorts (pic below).
Pic of panel
Pic of breaker w/pigtail
Questions
  • Since the coach outlet wiring is already isolated, do I need a subpanel here?
  • Do I need to separate the house wiring from the exist breaker that also shares the controller/charger?
Again, if I need to pay someone to do this, I will. I'm just trying to save as much as I can and move the project in a direction that I know is both safe and effective. The last RV shop I went to was going botch this whole thing and I just want it done right, and for as little as possible.
Thanks again for your help.
Tim
  • Hi,
    I use the whole house method. I do have a separate converter and inverter. That allows me to do double conversion when there is only a 15 amp outlet for shore power.
    My goal was to have the rv behave as if it were on shore power when ever it was in use. I've pretty much succeeded in that.
  • Just do it whole-house and don't run the air or MW. No sub.
    Canned answer:
    I'll offer an overview of inverter installation.
    There are 2 ways it's done: energizing specific circuits, or energizing the whole coach. The first consists of using a subpanel (another electrical panel with breakers), the second uses no subpanel.
    As you might imagine, the first is more 'foolproof' (you don't invert your air con circuit) but, much more work to install. The second is easier, and is like plugging your coach into a generator. The inverter becomes just another AC source.
    My inverter is done the second way, called whole house. The best part of this install ( I have a Prosine 2.0) is the circuit protection provided when you're on shore power. I have surge and sag protection, and even bad frequency protection. That's a life-saver when you're in a park with questionable power. The inverter becomes the power police for your entire coach.
    The downside is whenever you're invertering you must ensure the air and HW are off. But, isn't that what you'd do if you plugged into a generator?
    Here's a schematic:
    My system schematic
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
