exportman's avatar
exportman
Inverter wiring
I am planning to install a larger inverter in my RV. Currently have a small 400w unit but want to put in a 2,000 watt unit. Can I assume that I need to upgrade the wiring to the batteries? What size red and black wires are needed? Thanks.
    You haven't mentioned the wire length.
    The size of the wires you choose depends upon the current passing through them, their length, and how much voltage drop your inverter can handle at your max loads (bigger wire, less voltage drop).
    Bigger is always better.
    Who knows? ... you haven't told us how long the runs are. :R I used this Blue Sea chart to decide that 6' long 4 gauge cables were suitable for my own inverter installation, considering it's rated capacity and how I expected to use it.
  • Not to hijack tread but has same question.want to install a 2700W PSV Magnum cable length 5' from batteries to run a hairdryer, laser printer, and a small amount of microwave 1000W and including light and fan 1500W rated of 4 6V 280A batteries. ? cable size and fuse. Thank you.
    Frank.
  • ^^^^ I would go 4/0 with 300a fuse. See my link above. Unless the manual calls for larger.
  • Lots of good info .
    To Sound Guy:
    As I read your chart tell me please if I am reading it right. If I buy a 2,000 watt inverter and never use more than 1800 watts, I think I would be using 14 or even better 12 g wire. I got to this by dividing 110 volts into 1800 watts getting 17 amps. At <6 feet, the gauge wire is 14. Am I doing it right?
  • exportman wrote:
    Lots of good info .
    To Sound Guy:
    You need 1800 watts @ 12 volts which is 150 amps from the batteries to produce 1800 watts @ 110 volts which is 17 amps.
    Big wire needed from the batteries to the inverter.
    smkettner has it right
  • On the 12v side you will be drawing more than 1800 watts, probably about 2000 watts, or 167 Amps. The wire size depends on the length of the wire and your tolerance for voltage drop. 4/0 would be playing it safe, see SoundGuy's chart.
    Of course, your battery bank has to supply at least 12v at that current.
  • OK. Got it. Thanks everyone for the info and the lesson. 16 years of being on this forum and it never disappoints as to how many fellow RVers come to the assistance of others.
    For those helping me out (and for what it's worth) I am going to delay installing the bigger inverter until next winter. I will travel through Quartzite, AZ when all of the merchants and installers are there in January and have them install an extra 2 Trojan 6 volt batteries, the inverter and the heavy duty wiring. Heading to Alaska in Spring/summer 2017 and the upgraded inverter/ battery system will likely be needed.
    Thanks so much
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
