jeremywatco's avatar
jeremywatco
inverter wiring layout
Hi everyone,
Just bought a 600w Xantrex ProWatt and am getting ready to install. I'm planning on installing the inverter in a small pass through space that goes from one bin to the other side of the coach. Its literally 10" away from battery bank.
Now for my questions.
I bought a 100amp fuse and fuse holder and also a battery selector so I can disconnect the inverter while not in use.
Currently in my battery bank the positive cable goes about 6 inches and into a 150amp fuse. Can I just add my inverter terminal to this fuse block and call it a day? Or should I screw onto the battery and install a separate fuse block? Seems like I could just attach to the existing and be done..
Just not sure if the 150amp fuse wouldn't blow fast enough if there was an issue.
Thanks Jeremy
