djousma's avatar
djousma
Inverter/Battery/load combination
All,
I just took delivery of a new Cardinal 5er. Came with residential Frigidaire Refrigerator, Label says 8.5amp draw The coach also was wired with a Xantrex 2000W ProWatt SW dedicated to powering the refridge(nothing else wired to it), connected to a pair of 6volt GC10 golf cart batteries. Unit is also prewired for a onboard generator for later. All 12v wiring is within 18" between batteries and inverter. We never dry camp, really the inverter is only used when on the road to maintain refridge/freezer temps.
Fridge was precooled at home, when I left, I swatched the inverter on, and when disconnected from shore power, reefer continued to run. However, when we got to our destination 2 hours later, freezer had lost 10 degrees over two hours. Refridge maintained its temp. I suspect there are two separate compressors in this refridge.
Reading the XAntrex manual, they talk about "exceptional" loads, including freezer compressors. I have to do a little more troubleshooting yet, to see if the inverter is not getting enough DC power to start the compressor spike, but they do go on to say that a larger battery might be needed?
Dealer originally had two standard 12 volt batteries wired in parallel, but I told him I wanted a pair of 6 volt deep cycle wired in series.
Whats the recommendation here? should I have stuck with the dual 12V in parallel?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
