smooth1's avatar
smooth1
Inverter/Charger Question
Hello. I am looking at building up my battery set-up with 3 or 4 150amp AMG 12v jars. My goal is to be able to run the polar cub 9200 AC unit in my camper for 15-30 minutes at a time if & when we need to cool off. I am looking at an inverter/charger unit like the Xantrax RV2012, Xantrax Freedon Marine 20, and the Magnum ME2012 units with a 2000W inverter and a 100amp charger.
I have a Yamaha 2000 generator, 200Watts of solar, PD9245 system now and am hoping to not have to bring the genny to run the AC. I am basically only carrying the genny to run the AC. I know if I run the AC too much the 200W of solar is not enough, but I can upgrade that.
My questions are on the 100amp chargers on these inverters. Will the Yamaha 2000 be able to power those 100amp chargers if I need to charge the batteries when I winter camp. Also, is the PD9245 going to put enough amps into the 3-4 batteries or should I just take it out and use the inverter/charger only. If the 100amp charger won't work on the Yamaha 2000, then can I just leave the 9245 and switch to that to charge the batteries off the genny. I have heard a PD9280 won't run on a yamaha2000. Will the 100amp charger work on a 15amp 120v outlet from my house? Kinda confused on these larger chargers.
  • Some of the inverter/chargers with 100a or 150a chargers have their chargers "power-factor corrected" which will let them run on a 15a circuit and so the 100a would likely run ok on the "2000w" gen, but nearly max it out.
  • I have a PD 9280 and have run it on a Honda 2k. Gave her a workout in boost but no overload trip.
    Nonetheless I see no benefit in your situation to buying a big converter. Just go with an inverter/charger.
  • Hi,
    My magnum 3000 watt will charge at 125 amps from a 15 amp supply. The yamaha generator will do 16 amps continuous.
  • Most of these inverters can be adjusted to lower power ratings on the charging side.
    I hope you are looking at sine wave inverters only.
    9245 is fine but probably a bit slow for that many batteries. More solar would mitigate the issue. Staying with 9245 would allow you to just get an inverter (no charger) and save some money.
    I would plan on 4 to 6 batteries. If you really want to run the air periodically and leave the generator at home you are looking at 600+ watts of solar.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
