ford_truck_guy
Sep 01, 2015Nomad
VintageRacer wrote:
I would run the fridge from the generator if they are running. Fridge doesn't take much, and two eu2000's are well up to the task. My inverter would do that switch automatically and pass through the generator power directly to the fridge without me doing anything, and it would switch to charging the batteries automatically as well. You would basically be doing manually what mine is set up to do automatically.
Brian
well ,mine does that as well , I was just not sure which way would be better for the output..?? So it sounds like I will not touch a thing... keep it on float and let it automatically switch over..
