You do a few days off grid doing 50-80s where the Iota gets close to 80 by the time it gets the batts to 14.6 and drops to 14.2 and you stop the gen. Works great.
So now you go home and have days and days of shore power to do the "recovery" from that successive undercharging. To do that you need the batts to recharge at 14.8 until they are full and then some to do the overcharge for the recovery.
But you can't. The batts get to around 80% and the Iota drops to 14.2v and there is nothing you can do about it. Then the voltage drops to 13.6! SG is still in the red on the hydrometer. Now what?
Any hope the solar will work at home where you are parked? Any sun at that time of year?
Having BTDT I got myself a converter/charger that can stay at 14.8 for as long as I want and then I can crank the voltage to 16v if need be for the overcharge to get that SG up to spec. Can't do that off grid on generator of course, takes too long. It is what you do once back home. When the SG does get to spec, then I drop the voltage to 13.x (where X depends on the temperature) for the Float till the next camping trip.
