Salvo wrote:
You can trick it, shut down gen, turn on some loads to drop Vbat and then restart gen. The battery is however still close to 75% SOC. That means the battery resistance is high and the Iota will only be 15 min in boost.
At what SOC, all consumers off, except normal frige and CO sensor, does the Iota consider the battery recharge resistance high?
If you were to size Iota charge controllers to amp hours of battery on board, being recharged from 50% SOC via a generator, how many amp hours of battery capacity do you recommend for a 55 Amp version? 45 amp version? 30 amp version?
