Salvo's avatar
Salvo
Some cool battery graphs
I'm checking out the Costco GC2 batteries and Iota 55A converter as well as the new 16-bit a/d for Arduino.
Prior to discharging the 208AH GC2 batteries, they were top charged with 16V for about an hour.
They are then discharge to about 50% (actually 99.8AH) with a load current of 14A for 7 hours. The load current consists of a 100W light connected to a msw inverter and some lighting inside the MH.
Data is acquired using an Arduino Uno board, and a 16-bit a/d converter. Battery voltage and current (measured across a 100A shunt) is recorded every second.
The first graph shows battery voltage (in blue) and current (in pink) over the entire 7 hour discharge period. Voltage scale is on the left y-axis and current scale is on the right y-axis. Current is defined as negative when going out of the battery. Top of the graph is 0A and the bottom is -16A. The current oscillates due to inverter operation. It does not pull a constant current.
The second graph is same as first, but just looking at the first 30 min of discharge.
Like wise the third graph shows the first 5 min of discharge. The inverter is switched on at about the 3/4 minute mark to get -8A, and a little later the add lights were turned on to drop down to -14A. Battery voltage is naturally decaying (from time 0 to 3/4 min) because the 16V charging power supply was just removed.
What's surprising is that there are two different voltage discharge slopes. The first slope is fast, going from 14V to 12.4V in about 6 minutes. This may be the top charge. The second slope is very gradual, going from 12.4V to 11.8V in about 7 hours.
The next graph shows SOC with respect to battery voltage. The weird looking top I believe is due to the top charge.
The last graph is same as above, but the voltage is corrected for a no-load current. The internal resistance of the battery is 12 mohm. The load current multiplied by the resistance is added to the voltage measurement. I also started the plot before the weird looking top comes into play.
And here's the test set-up. The 100A shunt is connected directly the the negative battery post.
Charge plots still to come.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
