Gdetrailer
Jun 14, 2016Explorer III
Katman1100 wrote:
I am looking for a smart charger and am wondering if there is any major preference between these 2 brands? I would be sure that I purchased the smart charge model of either brand.
I did notice in looking at the PD9245 that it draws 725watts vs the IOTA DLS-45IQ4 drawing 600 watts. They are both supposedly 45amps. The only time I could see this making much of a difference would be if running of my honda eu3000 and trying to run the AC at the same time as charging and that may not be possible anyways. I do like that the PD9245 has a remote available and I can choose which mode it is in.
Is there any other differences I should look at? I do realize that some people prefer other chargers that have to be monitored, I just want something I can plug in and use as needed and not mess with it.
This will be to charge 4-6volts currently that may expand to 6-6volts if needed in the future. There is also going to be around 800 watts of solar once I am finished with the project so I can't imagine the charger will actually be used much.
Thanks for any input.
Since you are planning to add more battery, I would suggest bumping up to at least 60A.. I have a PD9160 with ext charge wizard pendant. The 60A capacity gives me plenty power and room for expanding battery capacity.
45A with six 6V batts will take a lot longer to charge which may be something to consider if your plans are to boondock with gen and solar.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
