time2roll
Jun 14, 2016Nomad
If you are running the air conditioner all day or night and want low power draw the 45 amp is fine, 30 amp would be fine.
If you want a fast charge go to 70+ amps. Especially with six batteries. This also needs short fat wire to be effective. May prevent the air from starting on generator if the battery is low.
Both are excellent. The data I have seen posted puts them about the same after four hours charging.
The float on the PD is a bit lower than the IOTA. This only matters if you are plugged in for an extended period and the temperature is very hot or cold.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
