BFL13's avatar
BFL13
Explorer II
Feb 06, 2015
Is 24v Charging the Same as 12v Charging?
With 24v charging on a 24v battery is everything the same as 12s except half the amps? Same charging profile, SOC vs time etc? Is 8.3 amps with 24v the same exactly as 16.6 amps on a 12v bank of the same AH capacity? (Do you express the "AH" as half too?--Please, no Watts here! :) )
If so it would be easy to compare results. With my 230w panel and MPPT I was getting 15.5a in the Spring and 13.5a in the Summer. With PWM I would get 14.5a all the time based on my 130w having 8.2 Isc. (which I got all the time no matter Spring or Summer)
The Isc of the 230w panel is 8.3 and in the Summer I often saw 8.4 or so. (Isc goes up with heat) Since I get Isc with a 12v panel I should get Isc with the 24v?
I notice that the 230w and the 130w have about the same Isc, so it is not twice really. Confusing. Panel brands do vary in Isc per Watt though.
I would sure take the 16.6 worth at 12 getting 8.3a on 24v instead of 13.5 on 12 if that is how it works.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
