Matt_Colie
Feb 08, 2019Explorer II
BikerRV,
If this is your coach, then keep this up. I hope you know that nothing good happens to an idling engine. Running at idle from a cold start may allow the engine to collect internal moisture and the HEGO will have to heat itself and this shortens its life. This may not be a bad plan if you rarely dry camp.
I am guessing that the 150 at CW is just an oil change. This is something that you could learn to do yourself. Then the cost would be about 10$ for the oil (No oil filter). The new tools would also cost less than 20$. Tools: A funnel, a Torx tool for the drain plug cover, a set of rubber mats to lie on.
We don't use our generator to watch TV. We use it to run the microwave or the A/C. Both of these would take a serious inverter. If you do this to charge the house bank as required, then that is also part of your plan.
I never let any body work on my coach, but then it is different than most.
Matt
Matt
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
