2oldman
Feb 08, 2019Explorer II
CoeyCoey wrote:Will you be running the inverter at 24 then ? Reason I ask is that even with higher voltages you need to be concerned with wire and connections heating up when running high wattages for long periods.
24 volts.
I run mine at 50 volts, and had to double-up the positives due to heating after about a half-hour. Some of that heat could have been due to too-small bolts on the busbars however.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
