pnichols
Feb 14, 2019Explorer II
I am sure part of the reason my 175amp alternator can only do 80-90amps to my batteries is Winnebago only did 1 awg wire from alternator ... snip.
Hmm ... my Winnebago Itasca only has 8 gauge wire running from the engine 12V system to my coach's AGM battery bank, and the Ford V10 engine alternator is only 130 amp.
When my coach battery bank is down around 50% (~12.1 volts) and with the V10 at idle, I've seen the alternator deliver up to 70 amps into the AGM batteries. This pretty much matches the power output curve versus RPM for Ford's E450 stock 130 amp alternator.
I can watch all this happening because I have a coach battery bank ammeter, a coach battery bank xx.xx voltmeter, and an engine battery xx.xx voltmeter mounted on the cab dash on the driver's side. Both voltmeters track very closely when everything is operating as it should.
When the voltmeters do not track, so far it's been because the solenoid that interconnects the engine battery to the coach batteries has failed - either failed to engage - or engaged but suffered from high contact resistance due to erosion of the contacts. This has happened twice now over the years. I now have installed an aftermarket heavy duty solenoid with silver plated contacts in place of the stock battery interconnect solenoid.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
