DrewE
Feb 15, 2019Explorer III
jharrell wrote:
Voltage Drop = Amps x Ohms.
8 awg wire is .63 ohms per foot, 1 awg is .12.
Length always matters. Voltage drop is power being dissipated as heat in the wire. 8 awg is pushing it for 70 amps even for a few feet if kept cool, usually not recommended for more than 40.
More here: https://www.bluesea.com/resources/1437
8 AWG wire is 0.63 ohms per 1000 feet, not per foot! Similarly for 1 AWG wire.
Particularly for low voltage circuits (or long wire runs) power loss due to wire resistance can be a constraint on wire size. Regardless of the wire run length, ampacity is a consideration. The standards used for current carrying capacity vary a fair bit, though; often automotive and similar low voltage systems are not as conservative as, say, the NEC requires for normal AC wiring.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
