jharrell
Feb 15, 2019Explorer
DrewE wrote:
8 AWG wire is 0.63 ohms per 1000 feet, not per foot! Similarly for 1 AWG wire.
Particularly for low voltage circuits (or long wire runs) power loss due to wire resistance can be a constraint on wire size. Regardless of the wire run length, ampacity is a consideration. The standards used for current carrying capacity vary a fair bit, though; often automotive and similar low voltage systems are not as conservative as, say, the NEC requires for normal AC wiring.
Thanks for the correction should have caught that. Doesn't change the premise, length matters, 10 feet of 8 awg will drop 12v 4% at 70 amps, that's 30 watts heating your wire plus half a volt less at the battery. I probably have about 20 feet total length from alternator to batteries the way its routed through chassis.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
