TenOC
Dec 06, 2018Nomad
guidry wrote:
Propane is probably cheaper but you’d have to refill whereas electric you don’t.
I am not sure that propane is cheaper because the RV furnace is not very efficient. If you have a unvented Mr Heater propane heater that is APPROVED for use in a close RV or other type catalytic heater. That is no problem with CO, the propane is cheaper. However, with an unvented heater water vapor can be a problem.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 08, 2026
