westernrvparkow
Dec 06, 2018Explorer
Distribution of that heat is much more important than the cost per BTU. Your furnace is designed to distribute the heat throughout the RV. You won't have to heat the living room to 110 degrees to get the bedroom above freezing. Your furnace will be more efficient than space heaters if you are heating the entire rig.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 08, 2026
