Sea_Six's avatar
Sea_Six
Is it cheaper to heat my RV on propane or electric?
I'm paying for both the propane and electricity.
43' fifth wheel with four slides- around 400 sf or so. 2013 Dutchmen. Winters here in NW FL are mild. We get 40-50° temperatures at night typically. Occasionally it will get into the 30's and we will have a few days of subfreezing weather per year.
I have a heat pump in the main ac but the reversing valve has failed so it's just an ac for now.
I have two 1500W electric fireplaces and they seem to do a good job of keeping the place warm enough for me and my Golden Retreiver.
But would I save money if I use the propane furnace instead?
  • I paid apx .21 per KWH in the RGV and heated with electric or propane. Mild winters cost per month was pretty much equal electric or propane. Apx $48 per month.
  • Prove it to yourself.
    Even if electricity was dirt cheap at ten cents a kilowatt hour just your two heaters would mean thirty cents per hour -- ten hours three dollars -- ninety dollars per month.
    But ten cents per kWh is like the days of the buck and a quarter breakfast special and grocery store Ten For A Dollar chicken pot pies.
    The actual cost is more like three times that. I remember my aunt in Seattle hooting "We pay three cents per kWh for power!" That was sixty years ago.
    Your propane furnace probably has 500% more heating power available.
  • If you pay per KWH, propane is cheaper.
    If electric is included in the sit, electric is cheaper.
