Old-Biscuit wrote:
All good advice^^^^^^
120V AC circuit breakers....reset ALL
12V DC fuses.....replace those 2 suspect ones
GFCI Outlets....check/reset any of them (kitchen/bathroom etc)
Converter
Verify that you have 120V AC Voltage to converter.either via a Circuit Breaker or at outlet converter is plugged into (some or hardwired/some use power cord)
Measure converter DC Output voltage ---should be 13.2V DC MINIMUM (if loweer converter has failed---replace)
As for fridge...
Not working on AC source (works OK on propane)...that tells us DC to fridge is GOOD (need it for electric AND propane)
Verify outlet fridge is plugged into has AC power (tripped GCFI??)
If outlet is hot them need to pull cover off of control module (backside of fridge---power cord/dc leads go to it) and check the 5A glass fuse. Bad...no AC.
If it is good then could be the electric heat element is bad
But think you will find tripped GCFIs...cause of no AC to outlet(s)
And having a GOOD surge protector would be a GREAT Tool for NEXT time. Progressive Industries (LIFETIME Warranty!!)
+1
Old-Biscuit always has the best and most accurate advise
