wa8yxm
Jun 29, 2020Explorer III
Well there are a few significant differences but not all that significant,.
The Big D'a cranker is a STARTING battery should be kept 80% or fuller State of charge the "Deep Cycle" is most likely a MARINE/deep cycle. note the change of case with a recommendation to keep it over 75% full
True DEEP CYCLE go down to 50 (or less with some of 'em) before serious damage happens,.
Beyond that I've seen all sorts of posts saying "DO NO MIX" Ignore them.
The stronger one will be dragged down by the weaker NO IT WILL NOT
The smaller one will charge faster and tell the converter to stop charging NO IT WILL NOT in fact that is impossible.
One exception and this applies if batteries are mixed or identical IF you have batteries in parallel, mixed or identical matters not. and one gets a SHORTED CELL then it will drag the entire bank down.. But Mixing makes no difference.
NOW: batteries in SERIES (Example 2 GC-2's to make 12 volts) or a 5 Cell Streamlight or maglight flashlight) The batteries need to be matched.. Replace one replace all.
That is where the myths about parallel hookups come from But for parallel they are myths.
ON one more comment
Mixing gc-2 pairs with 12 volt cans.. I do that. no problem
One pair GC-2
One each group 27 29 and 31 all working together flawlessly
(Note I'd have all 31's save the store did not)
ON one more comment
One pair GC-2
