landyacht318
Aug 06, 2017Explorer
That much sunlight getting through the fiberglass means the gelcoat is gone. I'd get some paint on the exterior as sunlight's UV light will deteriorate the fiberglass and the polyester resin used to saturate it.
I use rustoleum topside yacht enamel at about 15$ a quart. It is many times better than their regular enamel, but Interlux yacht enamel is 25$ a quart and much better.
Get some butyl rope for under the flange of the fan. Do properly prep the roof surface before adhering then screwing fan down.
Degrease before painting, paint longevity is all about the prep work
https://www.amazon.com/Second-Skin-Damplifier-Butyl-Rope/dp/B0155KELRW
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
