- SCADAMAN29325Explorer IIAgreed. I think it goes to that 'filtered water faucet'. Been working on other things, but will be getting to it soon-ish. Might relocate the filter or do away with it entirely.
- heyobieExplorerI'm not sure I like that inline filter design. They need to be changed and that looks dificult to get in there and remove.
- First thing I would do is remove the sink. Then, when you have room to work, you could move that filter anywhere you want.
- valhalla360Navigator
bobndot wrote:
I guess people have different sensitivity to certain bacteria’s than others.
My daughter is a food microbiologist and dw is a nurse , both bacteria minded and know more about this stuff than me. They were explaining the whole thing to me and were making me sick just listening to them.
Two against one. Easier not to argue. Even easier to crack open a Poland Spring and make the coffee. Makes my fishing experience less stressful.
Sometimes a little knowledge is a dangerous thing.
You would think that a microbiologist and nurse would understand that boiling water for coffee will kill pretty much all the bacteria...it might be worth using bottled water to keep the peace but there is no scientific basis.
I believe most of the sensitivity is a reverse placebo effect. They believe it's harmful, so their body reacts as if it is harmful.
To the original question: Change the filter or eliminate it and move on. If it really makes you feel better treat the water system with some diluted chlorine bleach. - bobndotExplorer IIII guess people have different sensitivity to certain bacteria’s than others.
Two against one. Easier not to argue. Even easier to crack open a Poland Spring and make the coffee. Makes my fishing experience less stressful. - 4x4vanExplorer III
bobndot wrote:
Being that you are not the orig owner, it might serve you best to use bottled water for drinking. At least start your trip that way and refill your water bottles from a safe source as you go.
Still can't understand why people are afraid of drinking water from their RV, regardless of what type of piping material was used. My last 2 RVs used the grey lines; we purchased the rigs used, flushed the system once when we bought, and then used them for 10-12 years each (yes, even "DRINKING" the water, OMG!). There is no danger from those grey lines other than they could become brittle over time depending on the water quality and develop leaks.
The undersink filter that is there, on the other hand, I would remove since you have no idea of how long it's been there. - 4x4vanExplorer III
Pbutler97 wrote:
I'd be willing to bet that the manufacturer "put those lines there".:S
You might want to ask who put the polybutylene supply lines here. That's some bad stuff and 28 years ago was the "pipe of the future" until it wasn't. Hope it was not used with high chlorine concentrations for extended periods of time. - Pbutler97Explorer
SCADAMAN29325 wrote:
Are you talking about the gray pipes, they're all over the place.
Yes. - bobndotExplorer IIIBeing that you are not the orig owner, it might serve you best to use bottled water for drinking. At least start your trip that way and refill your water bottles from a safe source as you go.
Search Acuva rv water purification. - SCADAMAN29325Explorer II
38,778 PostsLatest Activity: Jun 10, 2026
