time2roll
Oct 26, 2016Nomad
dougrainer wrote:Seen plenty of maintenance free with removable caps.time2roll wrote:
Battery should be fine to equalize. Do you have a hydrometer to indicate the process is needed?
If you have a Maintenance free battery, that means the caps are not removable. So, HOW do you then use a Hydrometer??????? Doug
And maybe that was the point. No hydrometer reading maybe it does not need equalizing.
Website is not real big on maintenance or charging specifications.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
