dougrainer
Oct 27, 2016Nomad
time2roll wrote:dougrainer wrote:Seen plenty of maintenance free with removable caps.time2roll wrote:
Battery should be fine to equalize. Do you have a hydrometer to indicate the process is needed?
If you have a Maintenance free battery, that means the caps are not removable. So, HOW do you then use a Hydrometer??????? Doug
And maybe that was the point. No hydrometer reading maybe it does not need equalizing.
Website is not real big on maintenance or charging specifications.
When I state removable caps, that means the Caps stick UP from the case. NOT flush where you have to use a screwdriver to pop them up. THOSE types you are not supposed to pop off those caps. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
