mbopp wrote:
Turn on 4 lights and check the voltage right on the converter board. If it's 13.6V or more the converter is good and you need to look for bad connections (and don't forget the grounds!)
I agree. If the batteries are not connected and if you are on shore power, the converter output should be 13.2 or so volts. The wiring diaagram should be on the panel door.
Hookup the batteries, disconect the converter (open circuit breaker), and check the voltage of the batteries.
Converters are easy to replace by yourself.
ken
