ib516's avatar
ib516
Explorer II
Apr 18, 2014
Is my converter fried? (TEAR DOWN NOTE)
RV won't run the slides out etc. even when plugged into shore power. I have confirmed shore power (my house) is good as microwave in the RV will work. I do not have an RV battery installed as they are still in storage in my house on a maintainer.
Using a digital voltmeter, and touching the terminals that would connect to a battery if there was one there was 10 to 11 volts. Terminals are not shorted in the battery compartment.
I installed an RV battery that measured 12.8V and is new, and when I connect the terminals in the RV to the battery, I still get 12.7 - 12.6V. I would expect 13.2V when plugged into shore power.
Converter is a WFCO-8900 series.
Thanks.
  • check the fuses on the converter first. Might be ones on the back of converter. If good it could be bad charge section of converter, which can prob be bought separately rather than a whole new converter. I hav replaced many charging boards on campers that use WFCO converters, seems they are about $100. Here's a link to ebay sellers of these boards: clicky
  • When I try to operate the RV lights (LEDs) there isn't enough power. The lights are dim, and the LPG leak detector, which is wired to the battery goes from green status to red when I flip on one small LED light.
  • The slides NEED the battery due to high amp draw. They are wired directly to battery.
    Converter alone is not enough ump
    Converter DC output should be 13.2V minimum when connected to shore power.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 21, 2025
