GordonThree
Jul 11, 2016Explorer
If money's no object, check out ReLiON. Their G31 case is a 100 amp-hour Lithium Iron Phosphate battery, and you get to use all 100 amps, none of this 50 percent bs like lead acid. You get thousands of cycles out of it, vs only 100s from lead acid. Plus it only weighs 30 lbs!
http://shop.relionbattery.com/collections/12v/products/12v100ah
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
