landyacht318
Jul 11, 2016Explorer
The two story Lifeline Group 31 is the Lifeline GPL-30HT rated at 150 Amp hours.
When looking at its specs, one might infer the plates are even thicker than the gpl-31XT, and not just taller.
Much more weight for only 25Ah more capacity, and not much more cca either.
I briefly had a GPL-31XT (125AH)in my possession when it was new.
its fully charged resting voltage was 13.16v or higher.
it had absolutely no issues sucking up 100+ amps from a fast spinning capable alternator when depleted to 50%.
Impressive battery.
Not sure if it can handle a residential fridge for long enough for the OP, but if the height is there to fit this tall boy GPL-30HT, then Me thinks it would a very good option, as long as one can be bothered to high amp recharge it at no less than 20% rate, and can regularly achieve a true 100% State of charge
Impressive battery.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
