anon125
Nov 01, 2014Explorer
jrnymn7 wrote:
If it's only to be used as a converter, wouldn't a switching power supply work well for this application? And how many amps max are needed at any given time?
http://www.12voltpowersupplies.us/
Anon, are your batteries and converter close to one another, or far apart like with so many factory installs?
If they're far apart, may I recommend using a power supply as a converter. Charging from the other end of the rig means needing long heavy cable between converter and batts.
they are next to each other. thanks
