D_E_Bishop's avatar
D_E_Bishop
Is the pendant for PD Converter chargers worth while?
My 23 year old PD converter was dying so I installed a Series 9200 converter/chargers and kept the old panel and transfer relay. Everything is good now but I forgot to install the Pendant. I miss the indicator light showing the status of the charge, high rate, low rate or maintenance. I miss that indicator light and wonder if there is a simple device that I can install with out having to remove the entire distribution panel can. If I have to do that I can get to the converter and plug the pendant in. The problem is I have to disconnect all the wiring and remove the can to plug in the pendant.
  • Yes, you should have the pendant, unless
    you don't mind settling for slower battery charging at times.
    Quite often my 9245 does not go into boost mode when starting out, and I have to bump the button on the pendant. But, w/o the green lite, you won't know that, and what you don't know won't hurt,.....or will it ??
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
