D_E_Bishop's avatar
D_E_Bishop
Is the pendant for PD Converter chargers worth while?
My 23 year old PD converter was dying so I installed a Series 9200 converter/chargers and kept the old panel and transfer relay. Everything is good now but I forgot to install the Pendant. I miss the indicator light showing the status of the charge, high rate, low rate or maintenance. I miss that indicator light and wonder if there is a simple device that I can install with out having to remove the entire distribution panel can. If I have to do that I can get to the converter and plug the pendant in. The problem is I have to disconnect all the wiring and remove the can to plug in the pendant.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
