enblethen
Aug 04, 2020Nomad
You should not use a valve! The Atwood nylon plug is the one you should use or the Camco replacement. It is designed to be hollowed out to help prevent tank damage in the event of freezing. Using a socket and extension makes it very easy to remove to drain tank.
Plug should be nylon and not plastic.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
