dougrainer
Aug 04, 2020Nomad
https://www.acehardware.com/departments/automotive-rv-and-marine/recreational-vehicle-parts-and-accessories/rv-water-system-equipment/8377319?gclid=EAIaIQobChMIp52UgqaC6wIViYbACh0W1Q_xEAQYBCABEgLZGfD_BwE&gclsrc=aw.ds
https://www.etrailer.com/RV-Fresh-Water/Camco/CAM22243.html?feed=npn&gclid=EAIaIQobChMIp52UgqaC6wIViYbACh0W1Q_xEAQYBSABEgKiR_D_BwE
This is the drain valve and it is for the Fresh Water tank drain. Yes, you can use a brass drain valve and adapt to fit the drain hose from the tank or if yours is attached direct to the tank, just find 1/2 inch thread valve or adapter to 1/2 inch threads. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
