wa8yxm
Aug 05, 2020Explorer III
On atwood water heaters DO NOT USE A METAL VALVE..
I have used, with limited success. a short CPVC pipe then a brass valve
But.. Only limited success.
One option is a plastic (nylon) to barb fitting and a short hose with you choice of valve on the end. Be sure to use a hose that can take the degrees F.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
