BFL13
Aug 04, 2014Explorer II
Your 2000w inverter to run your microwave, kettle, toaster, hairdryer, vacuum cleaner, leaf blower, etc can be inside with the batteries, and the batteries for the inverter do not need any ground to the frame from the batteries, just the pos and neg inverter-battery wires (pos wire fused).
You can leave another set of batts on the tongue for the regular rig-running duty.
The solar controller can charge both sets simply by paralleling the two banks with any old jumper cable set that will reach between them.
I suppose moving the batts inside is to make room on the tongue for the Honda 3000, so in that case, yes you need to find the positive wire that goes from the battery fuse now to the pos battery terminal, and re-route but don't forget to shift the battery fuse too.
Oops I forgot Almot is the OP :)
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
