dougrainer
Nov 19, 2016Nomad
JimInMich wrote:Canadian Rainbirds wrote:
I'm guessing that heater is a "Bus" heater, a heat exchanger takink engine heat from the engine cooling system. Our old Triple E Commander Class A had one, worked great as long as the engine running!
No, it's a propane heater ( could be electric, haven't tried it without shore power hooked up ). I get heat from it while engine is off.
1. It is NOT an LP heater(Too small)
2. It is NOT a Electric heater
3. It is NOT a Sol-aire heater
4. If it is a optional rear heater and is connected to the chassis engine IF it has a motor or radiator in it
5. If no motor/radiator, it is a metal distribution box for the Furnace duct work.
6. They do not build 120 or 12 volt heaters like that for RV's.
7. What about those blue and red wires that appear to go into that black box. Do they go in that box? Doug
