JimInMich
Nov 20, 2016Explorer
Canadian Rainbirds wrote:
I'm guessing that heater is a "Bus" heater, a heat exchanger taking engine heat from the engine cooling system. Our old Triple E Commander Class A had one, worked great as long as the engine running!
I'm assuming you were correct. I got down there and got better pics. It has a radiator. Problem with this is I have no clue on how to turn it on. All I can find is a thermostat for the LP furnace in the bedroom.
But, there is also a larger LP furnace, that was further back under the bed ( I didnt see before ):
Found the name plate on the converter:
I'm going to upgrade the converter.
